Drive side seal not air tight
carlos fandango
How much air / pressure are you pumping in ? It should only be about 8psi , too much pressure and any seal will leak .
alanscottj
carlos fandango wrote:How much air / pressure are you pumping in ? It should only be about 8psi , too much pressure and any seal will leak .
6 psi :D
alanscottj
Hallelujah!!! She is air tight :D :D :D
Replaced the seal and the hallite washer bit, found I tiny leak on the inlet manifold sealed her all up and happy flippin days, the dial ain't moving at all. Only took three days!!!! I have never bothered leak testing before and have learnt the hard way with seizes and holed Pistons. So, not saying it will never happen again but at least I have learnt a little more about engine building and that can only be a good thing. Thanks again for all the help on here :D
stokky
Make sure you smear a tad of grease round inside of seal, so it slips over crankshaft easily
they can get folded if not
Martin
