Re: Very stiff clutch.
Posted: Wed Oct 21, 2015 10:46 am
When you pull the lever to compress the clutch you are pushing the pressure plate and springs inward and compressing the springs.Either the fingers of the pressure plate are tight were they fit into the spider or the pressure plate is to tight in the sprocket.Or the springs are to strong,or the cable is binding.
