Keeping it all together?
alanscottj
coaster wrote:
wack 63 wrote:I'd be checking the crank for true as well.
With some ingenuity and a dial gauge it is quite possible to do this with the engine insitu with the gauge pointer running on the outer end of the taper.
I think i'll get someone to have a look for me ;)
10 inch Terror
Xbox live gamer tag: No.
Loctite 243 and I use a loctite spray activator. As mention make sure both threads are clean.
dave411
Main scooter: Li 125
Spring washers and a dab of Loctite,job done.
CANbus
coaster wrote:Also, it's no good putting Loctite on dirty treads, use brake or carb cleaner to clean the bolts and threads in the case and allow to dry before applying the threadlock.
bumped again, good point.
11111111 = 0xFF
