Harry Barlow Stage 4
wack 63
Main scooter: '71 GP TS1
The packer is used with a standard stroke to raise the port timings
What's the port measurements like on that?
ducksta
My m8 just has the standard barlow tune on his px standard carb sito plus exhaust fast flow tap ran from york to mersea keeping up with everybody no problem even the lads on the avantis every time we filled up he had used no where near what we had used good rally going tune
Shuggie
thanks for the replies........gonna bite the bullet and order one up cheers!!
ColB
Main scooter: Vespa P200E
Ah right.. I take it, this comes with the Harry Barlow kit?
Spanish Fly
Main scooter: P200e
wack 63 wrote:The packer is used with a standard stroke to raise the port timings
If I'm not mistaken he does a long stroke (60 mm) version as well.
Does anyone know what's involved there regarding packers or recessed heads etc.
SF
stonerosesmod
Main scooter: Lambretta Li150S
With mine he supplied a packer plate to go under the barrel,machined the head so it dropped back into the bore the correct depth again,and ported the barrel and piston by hand as well as checking everything over.Mine runs the standard crank,set ignition to the IT mark and up main to a 128.Not wheelie fast like a polini but definitely more punch than standard.And if it went bang,i can just stick a standard top end back on.He does 208 kits to which he supplies also and that goes up to 218 with a 60mm crank which my mate has.Very torquey!
ColB
Sorry gents, one last question. Would this setup benefit from a t5 fourth gear?
stonerosesmod
Unless your particularly heavy and struggle in 4th I would say no.Probably best putting a T5 forth in a revvy malossi or the like.With a SIP 2 exhaust this setup is plenty grunty enough for me.
johnny rotten
Main scooter: px200e
SF
The packer and recessed head are only for the standard 57mm stroke crank from what I was told by HB on the 60mm version he just modifies the head to accommodate the extra stroke length
    Users browsing this forum: Baidu [Spider], Google [Bot] and 1 guest
