Page 2 of 2
Re: Best carb for a TS1 + JL3
Posted: Mon Aug 17, 2015 7:53 pm
by alanscottj
Cut a hole in the panel today, just need to find a grill now to finish her off, thanks for advice as always, most appreciated
Posted: Mon Aug 17, 2015 8:01 pm
by alanscottj
Now I have a hole in the carb, no filter, do I need to cover with mesh? Or leave as is, so as not to retrict air flow?
Posted: Tue Aug 18, 2015 6:09 am
by gppaul
on my TS1 I run a TMX 35 with a LTH manifold and I have a air filter fitted, its uses no more petrol then my mates with a 30 delly.
Posted: Tue Aug 18, 2015 6:03 pm
by speedy
On my S type TS1 which I have owned from new, I have a tiny hole the size of a ten pence cut in the panel. This was because the 34mm Amal mk2 banjo would catch the panel. The bellmouth of the carbs were also machined down , so that the carb would fit under the GP panel. I have since moved to a 30mm flatslide Dellorto. This uses the standard AF Ts1 manifold and the stepped rubber and is no way near the panel. Can't see why yours has fouled the panel,cheers.Speedy.
Posted: Tue Aug 18, 2015 10:31 pm
by Yanker
Why all the carb shortening and hole cutting when a genuine Keihin PWK (28/33/38mm) is the better carb allround without that hassle?
Posted: Fri Aug 21, 2015 10:39 pm
by shocky
Yanker wrote:Why all the carb shortening and hole cutting when a genuine Keihin PWK (28/33/38mm) is the better carb allround without that hassle?
There a much better carb and easier to set up ,the 35mm retails for about 180 gbp , someone I know just fitted a 35mm to his ts1 230 and has a 3.5bhp increase and 4 ftlbs of torque previous carb was a tm(x)32
the carb came from PSN he was told they fit them to ALL there ts1,s
