Page 2 of 2
Re: BRETTA WON'T START WHEN NOT STARTED A FEW DAYS
Posted: Fri Aug 14, 2015 10:13 am
by idc23
When she it starts it runs clean, just seems weird it starts after a few days, but leave it for a week or two it wont, i think what wack says might be true ?
Posted: Fri Aug 14, 2015 4:49 pm
by Chris in Margate
Yes I agree with what Wack says but I can start my scooter after a couple of weeks ( more like days in truth as I use it a lot) without issue 2nd kick every time and I mix my oil just like everybody else.
Definitely fuel related. Check flow from fuel tap into a bottle. Check carb filter. Remove any inline fuel filters if fitted. Check float assembly to ensure it is free to allow fuel to flow.
Posted: Fri Aug 14, 2015 5:58 pm
by idc23
Ok will bin inline filter, thanks
Posted: Fri Aug 14, 2015 7:12 pm
by coaster
coaster wrote:Always keep the throttle closed when kicking it over, especially from cold. You'll find it fires up much easier.
You didn't come back on my comment above, it's surprising how many people wring the throttle whilst kicking it over which just results in a weak mixture. Try it with the throttle firmly closed for a few kicks and see if it's any better.
Posted: Fri Aug 14, 2015 7:38 pm
by Chris in Margate
Aha. Filter !
Let us know the outcome. (Keep that throttle shut!!)
Posted: Fri Aug 14, 2015 7:58 pm
by idc23
Throttle shut, will remember that .
Posted: Wed Aug 19, 2015 8:14 am
by Chris in Margate
So what was the outcome as I see you're riding it albeit with a few problems.
Posted: Wed Aug 19, 2015 2:29 pm
by idc23
Think it was down to me giving it throttle , seems to start a lot better with no throttle, just got the problem of revs hold up like it is weak from a fast run.
Thanks Ian
