Page 2 of 3
Re: Have I screwed up my new flywheel bearing collar/ race?
Posted: Tue Aug 11, 2015 3:02 pm
by ArmandTanzarian
tippo88 wrote:Thanks all. Going to replace to be on the safe side . Need to find myself an old sundance grip- there must be a good market for them !
Just make sure you don't bend the crank when you hit it
Posted: Thu Aug 13, 2015 3:53 pm
by KCB
Crank in the freezer, bearing collar in just boiled water, just a few slight taps required with correct size drift / long socket supporting the crank against your body as per Stickys book or use a web spacer to stop any twisting
Posted: Sat Sep 12, 2015 6:11 am
by tippo88
On on that didn't go well. Removing the bearing race with a grinder, put hose clamps on for protection and went slowly and carefully but no crack line appeared , at least to my old eyes, and have ended up putting a flat on the nearing surface of the crank. Guess I'll get a new crank built at least can rescue the con rod ! Painful lesson learnt !
Tippo
Posted: Sat Sep 12, 2015 6:12 am
by tippo88
Posted: Sat Sep 12, 2015 1:22 pm
by rosscla
Put some trousers on FFS
Posted: Sat Sep 12, 2015 1:57 pm
by cgt75b
rosscla wrote:Put some trousers on FFS
Pmsl nice one rosscla.
Posted: Sat Sep 12, 2015 5:56 pm
by tippo88
Bit hot for trousers in an outside workshop in Malaysia :)
Posted: Sat Sep 12, 2015 6:10 pm
by tippo88
But next time I do this I'll try with trousers !
Posted: Sat Sep 12, 2015 7:05 pm
by shocky
I think your crank will be fine like that just use some bearing retainer
Posted: Sat Sep 12, 2015 10:59 pm
by rosscla
Was just thinking of Health and Safety...grinding unprotected and all that...
PS agree with shocky that'll clean up.
