Page 2 of 2
Re: BGM AFR Electronic Ignition
Posted: Mon Aug 03, 2015 8:50 am
by Strummer10
Its all getting too fiddly and technical nowadays, as you say shims under pick up boxes ?? I know when I used the very light AF flywheel (lightest out there) it had to be perfectly lined up with the magnets on the stator pick up, even then it wasn't firing too well, so I reverted back to SIL mid weight and put the stator back to original height and has been running like a dream. Also found the very lightened flywheel too light for a ride bike, with no 'run on' so had to keep revving to keep it moving bottom end
Posted: Mon Aug 03, 2015 9:01 am
by FREAK
ive a machiened mag flange for the bgm af combination 1mm off the stator face works fine :D
Posted: Mon Aug 03, 2015 9:33 am
by Strummer10
I stay SIL parts from AFR, then there's no problems :) lol OR so I currently hopes !!
