Page 2 of 2
Re: CHT readings?
Posted: Thu Jul 30, 2015 10:38 pm
by eden
have you tried putting the sensor in boiling water to see how fast it rises and if it reaches 100C?
Re: CHT readings?
Posted: Thu Jul 30, 2015 10:45 pm
by Fux
Nope, good point. Think I`ll try the one i have taken off first to see which one is dodgy.
Re: CHT readings?
Posted: Fri Aug 14, 2015 9:28 pm
by Bufficus
Westach gauge under the plug sensor.
Tuned TS1 with Ron Moss head.
100-150 Celcius.
Re: CHT readings?
Posted: Sat Aug 15, 2015 11:28 am
by dansacred
tuned ts1, clubman, pwk30 150-160 have seen 180c though
Re: CHT readings?
Posted: Sat Aug 15, 2015 12:44 pm
by Fux
My SIP sensor under plug, 155 celcius at full whack over a longer perioud.
Around 135 cruising.
Re: CHT readings?
Posted: Sun Aug 16, 2015 12:26 am
by Rick
On top of the plug between 170-180F running an Avanti
Re: CHT readings?
Posted: Sun Aug 16, 2015 9:01 am
by shocky
Rick wrote:On top of the plug between 170-180F running an Avanti
what sensor do you have i have the sip speedo and it reads about 185 but from cold the sensor reading is alreadt 130
Re: CHT readings?
Posted: Sun Aug 16, 2015 9:20 am
by Tractorman
What is the consensus on the seize point.
Re: CHT readings?
Posted: Sun Aug 16, 2015 11:02 am
by rosscla
When the piston expands to the point it has no clearance on the barrel.
Don't think you'll be able to quote a precise figure on that as it will be different on different engines.
Re: CHT readings?
Posted: Tue Aug 18, 2015 9:31 pm
by Rick
shocky wrote:Rick wrote:On top of the plug between 170-180F running an Avanti
Mines sip as well but it will drop to the air temp near enough when cold
