Page 2 of 20
Re: water cooled twin
Posted: Sun Jul 26, 2015 12:06 am
by JETEX
Wow !
Posted: Sun Jul 26, 2015 9:13 am
by holty
IMG_0951_zpswz2rvcyp by
stephen holt, on Flickr
IMG_0952_zpsqoh0hixm by
IMG_0953_zpsc5a0ysp2 by
stephen holt,
IMG_0957_zpsupel2vda by
cleaned the carbs yesterday, then replaced all the jets screws gaskets needles, to recondition the carbs, then tried to fit them, except they wouldnt fit, they did fit on my dry build, but when i rebuilt the engine i fitted reedblock spacers, with the angle of the engine it reduced the space between the fuel tank and the carbs. so i got the carb tops in the lathe and made them shorter, bent the cable tubes a bit more, repostioned the tank slightly higher up,and now they fit, i just need rubber fuel lines with a 90 degree bend now, to connect the carbs to the vacumn fuel tap, i also had to make a new balance tube to link the two carbs together.
holty
[img
S7002305_zps3e5fgqyv by
stephen holt, on Flickr][/img]
S7002304_zpsujvwtx6r by
stephen holt, on Flickr[/img]
im just adding some more build pics here, as photobucket has frozen lots of accounts ive had to change all th pics to flickr, i will try to keep them in order.
S7002307_zpshcja9trq by
IMG_0965-1_zpsxtjb8r4n by
IMG_0967-1_zpsn4dpqhc0 by
IMG_0966-1_zpstfmftzpb by
Posted: Sun Jul 26, 2015 9:49 am
by wack 63
Stunning
Posted: Sun Jul 26, 2015 9:55 am
by Boo
Amazing
very tallented
Posted: Sun Jul 26, 2015 10:43 am
by coaster
That is truly impressive, I could stare at the engineering and paint for hours
Posted: Sun Jul 26, 2015 5:27 pm
by ArmandTanzarian
Brilliant work. I wish I had half that skill.
Posted: Sun Jul 26, 2015 10:31 pm
by GBCS
Posted: Sun Jul 26, 2015 10:50 pm
by KatoombaBob
That is cooler than the frozen wastes of the Tundra, love it
Posted: Mon Jul 27, 2015 8:45 pm
by GBCS
Posted: Mon Jul 27, 2015 9:07 pm
by coaster
Nice
is that a Zip front wheel? I have one in mine with the calliper on the same side and was wondering what you were doing for a speedo drive (if you are fitting one) as it will run backwards...at least mine does
Colin
