water cooled twin
JETEX
Wow !
holty
Main scooter: lambretta gp
ImageIMG_0951_zpswz2rvcyp by stephen holt, on FlickrImageImage
ImageIMG_0952_zpsqoh0hixm by stephen holt, on FlickrIMG_0953_zpsc5a0ysp2 by stephen holt, ImageIMG_0957_zpsupel2vda by stephen holt, on Flickr
cleaned the carbs yesterday, then replaced all the jets screws gaskets needles, to recondition the carbs, then tried to fit them, except they wouldnt fit, they did fit on my dry build, but when i rebuilt the engine i fitted reedblock spacers, with the angle of the engine it reduced the space between the fuel tank and the carbs. so i got the carb tops in the lathe and made them shorter, bent the cable tubes a bit more, repostioned the tank slightly higher up,and now they fit, i just need rubber fuel lines with a 90 degree bend now, to connect the carbs to the vacumn fuel tap, i also had to make a new balance tube to link the two carbs together.
holty
[imgImageS7002305_zps3e5fgqyv by stephen holt, on Flickr][/img]
ImageS7002304_zpsujvwtx6r by stephen holt, on Flickr[/img]
im just adding some more build pics here, as photobucket has frozen lots of accounts ive had to change all th pics to flickr, i will try to keep them in order.
ImageS7002307_zpshcja9trq by stephen holt, on Flickr
ImageIMG_0965-1_zpsxtjb8r4n by stephen holt, on Flickr
ImageIMG_0967-1_zpsn4dpqhc0 by stephen holt, on Flickr
ImageIMG_0966-1_zpstfmftzpb by stephen holt, on Flickr
wack 63
Main scooter: '71 GP TS1
Stunning 8-)
Boo
Amazing :) very tallented
Lambrettas are for life!
That is truly impressive, I could stare at the engineering and paint for hours 8-)
ArmandTanzarian
Brilliant work. I wish I had half that skill.
GBCS
Main scooter: Lambretta GP RB250
Some update photo's from today:
It doesn't get much sexier than that :D
KatoombaBob
Main scooter: GP200
That is cooler than the frozen wastes of the Tundra, love it
GBCS
Todays update:
Nice 8-) is that a Zip front wheel? I have one in mine with the calliper on the same side and was wondering what you were doing for a speedo drive (if you are fitting one) as it will run backwards...at least mine does :?
Colin
    Users browsing this forum: No registered users and 63 guests
