30 mm Dellorto ok for a TS1.
ktmh5
Main scooter: GP225 Mugello
Andy W wrote:Hi Rich
When say Mild tune, what's been done?
Doesn't look like i am too far away, be interested to see what you end up with after Dan has dyno'd it.
Andy
Just a bit of porting, matching and flowing really. Even I won't know the result for 2 weeks as I have left it with him and gone on holiday.
Rich'
Andy W
Main scooter: GP 186 Imola
Rich any updates on your settings!
ktmh5
Hi Andy, yes here goes:-
AV266
X13 (was X7) clip 2 from top
Main 148 (was 135)
Slide 40
Pilot 55
Choke 70
Float Valve 300
Dan put a half clip washer in to make it clip 2.5 but it ran far too lumpy in mid-range so took it out on Dan's advice and now runs lovely. 24.2 bhp, 18 lbs torque, very pleased.
Rich'
Andy W
Hi Rich, thanks for the setting info, is this with or without a filter? do you have a hole cut in the side panel? As mine is fitted with one the MB panel filters, I may need to take this off and don't want to cut my side panel either. 148 is a big step up from 135, I currently have a 142 in mine but will need to buy in some bigger ones i think. Want to get it running somewhere near right as I now don't have a local Dyno and will have to travel some distance to get on one.
Cheers again Andy
