Re: 60mm crank and 1mm packer
Posted: Thu Jun 18, 2015 1:00 pm
check and re-check your timings before you take the plunge and cut metal.
if your port timings check out you will need to raise that exhaust port as thats woe-fully small.
as others have said minimum 170, i personally would aim for 180+ but this is where you decide what kind of tune you want, and how much else youre prepared to do, as you will probably need to raise your inlet timing to match. gearing and exhaust choice become crucial factors too, and how you like to ride.
to keep things simple you could just raise port to 170/175 for what most call a stage 4 tune.
