Page 2 of 2
Re: Piston Travel???
Posted: Thu Jun 11, 2015 8:40 am
by Architecten
Horror more like...
After discussing this in the pub last night the latest theory is the gudgeon pin circlip has come out and is hitting a transfer port. We'll see...
Posted: Thu Jun 11, 2015 3:35 pm
by Special X
Have you got a HPC crank? these regularly twist and also at the same time sling the weighted plugs into the path of the con rod. A twisted crank will definitely cause an air leak by distorting the timing side seal as it rotates. I've had 3 £300 HPC cranks twist on me so I won't ever use another.
Posted: Thu Jun 11, 2015 6:24 pm
by Chris in Margate
Once burnt; twice shy. 3 times !
Posted: Fri Jun 12, 2015 8:09 am
by Architecten
The conclusion is somewhat simpler. When I took the head off this fell out...
At first I thought it was an electrical connector but then realised it was the nipple off the spark plug! It must have fallen in when I took the plug off. I wondered where it had gone...!!! Four of the nuts on the head were loose so it was probably letting air in so it's a good opportunity to rebuild an decoke the piston as well...! Cruddy...
Posted: Fri Jun 12, 2015 8:26 am
by Chris in Margate
No !!!!
And after all those brilliant diagnosis we all gave !
Posted: Fri Jun 12, 2015 8:32 am
by Architecten
Heh! Good news for me though... my only expense will be a tube of silicone!!!
