BGM PWK 28 idle behaviour
koomwah
If it is slow to return to tickover that is usually a weak mixture leading to heat build up, could be an air leak somewhere - have you leak tested the top end? - or it could be jetting! Best to go up with jetting until it gets boggy then come back down to be safe
Sent from my HTC One using Tapatalk
