Page 2 of 4
Re: Lambertta Colour?
Posted: Sat Aug 01, 2015 2:57 pm
by barnsleybilly
Bristolmods got the only surefire way of finding a clue - you need to look where blasting & resprays are unlikely to have touched it - inside the frame headstock and in the engine mount tube on the frame are a couple more places to investigate.
Posted: Sat Aug 01, 2015 11:27 pm
by DaleUK
So other than the above there's no real , sure way of knowing from frame and engine number?
Posted: Sat Aug 01, 2015 11:37 pm
by rosscla
Correct
Posted: Fri Aug 07, 2015 4:08 pm
by DaleUK
Did a little bit more Digging as they Say... Found this Colour
Any ideas??
Posted: Fri Aug 07, 2015 4:09 pm
by DaleUK
Might need to Zoom in on lock catch!
Posted: Fri Aug 07, 2015 6:41 pm
by Daggs
The lock/catch would not have been painted by Innocenti.
Posted: Fri Aug 07, 2015 7:20 pm
by Doom Patrol
I think you're probably right. I doubt Innocenti would have sprayed it in situ and plastered the rivets and all.
Posted: Fri Aug 07, 2015 8:34 pm
by Grumpy225
bristolmod wrote: If its an li125 s3 it's probably duck egg blue
In the US it's been called Riverside blue, LI Blue, Baby blue etc etc.
At the end of the day I call it a manly blue
Reality is your LI was either blue or mint green, pick a color and run with it.
If you can find a little spot under the frame loop that wasn't painted over you MIGHT be able to ascertain what color it was from the factory. The blue and green look a lot alike after 53 years.
There are no color descriptors tied to frame numbers (unlike modern cars).
Posted: Fri Aug 07, 2015 10:14 pm
by DaleUK
How many Colours were used in '62
Posted: Fri Aug 07, 2015 11:49 pm
by Doom Patrol
