The crank in the post is made by the same crank manufacturer as MB's full circle cranks, they are both computer aided balanced to suit Lambretta pistons, so Im told! The pictured crank took 10 tons to assemble both side, runs with no run out, and would fit it to any race engine without a doubt....maybe even a group 4!
There are various ways to increase crankcase compression, a new crank is just one way, balance is a factor also worth looking at. A smooth engine, should give better power and lower vibrations, perhaps this is more of a consideration than compression?
Whilst Charlie is probably (so im told) bordering on genius, and was certainly the first person to talk about LPC in a magazine.....i dont think its fair to say that
nobody ever thought about it before? Cranks like this are not new in Lambrettas.......MB did a crank like this in 1990 in a LC Lambretta, its still running today! As for Low or high compression, everyone harps on about
cranks and compression........but no one mentions the fact that various combinations of Lambretta pistons with different comp heights, con-rod lengths and packers alter comp ratios......then everyone opens up transfers, welds them, makes big ear transfers and that all lowers compression too!
But saying that, some tuners have are getting good power from UN welded TS1 engines, rather than totally over the top welded engines, proving high comp still works! It's all to do with how you get your power, how you want it delivered, and in what context the LPC/HPC is working with other componenets......but its not new.
So, as we mentioned in the previous raging debate on this very matter, when we featured our version of a similar style crank:
http://scooterotica.org/forum/viewtopic ... +new+crank I guess that MB are seeking the same thing we are........
1) A decrease in rotating mass.......ever seen BHP increase when a lightened flywheel is fitted? Same principle.
2) Increased crankcase volume to lower primary compresion (to work with other componenets for an appropriate tune)
3) A better balanced crank with reduced vibration
Since we opened the dyno i have been rushed off my feet, and so havent had time to complete the engine that i fitted our crank to.....plus i dont really have a proper purpose for the engine, other than building it for my own amusement and testing etc, so its gone on the back-burner for now.
Plus....even if i had completed the engine, and it had put out great HP....no one would have been satisfied until i stripped it and fitted a standard crank to give a back-to-back comparison, so it seemed like a thankless task (not to mention costly). So i resided to do this instead...at the end of the race season, i will dyno the TS1 and i would be stripping that for a new piston and service anyway.....but i'll rebuild it with the cut-race crank of ours (see other post) and then i can dyno and give you the info you all want to know....back to back BHP figures.
Im not trying to convince anyone that this is the right way to go, and Charlies article in scootering didnt prompt Sean to do our version....he's been fitting them to Vespas for years, we just wanted to try it in a Lambo, and let you know what we were doing. So its OK if you think its all tosh....we're not doing it for you.
But, as to why MB are doing it, and what test results and info they have from these cranks.....well, only they can tell you that....but Mark doesnt produce random bits on a whim, he puts out good stuff (and lots of it) so if this is an option he wants to pursue, you can bet there's a good reason for it. Im sure his HPC cranks are the right crank for one type of engine, and his LPC cranks are right for another....but if you're going to better the best...who better to do it?
Its just nice to see that Sean and i arent on our own with the crank thing.
