Page 2 of 3
Re: Avanti Jetting
Posted: Mon Apr 27, 2015 7:57 am
by monkey boy
Fighting with the bottom end on mine.
Gone to a 45 slide and right down to a 50 pilot.
Av266 x7 needle 122 main.
Supertourer pipe and I can only say it's still way too rich at lower revs.
Riding in town is terrible,
Re: Avanti Jetting
Posted: Mon Apr 27, 2015 10:40 am
by Adam_Winstone
This is exactly how mine was when I fitted my Supertourer, whereas bottom end jetting and performance had been fine with other pipes, suggesting to me that this might be more an issue of pipe being out of the power and burbling, rather than the jetting being the problem.
My solution was to fit an Agusto 6K unit, which worked, thankfully, otherwise my new pipe was coming back off! Others have voiced similar experiences.
Adam
Re: Avanti Jetting
Posted: Mon Apr 27, 2015 1:10 pm
by monkey boy
I have mtech fitted on setting B or C can't remember which.
Retarding from 23 degrees.
Re: Avanti Jetting
Posted: Mon Apr 27, 2015 1:29 pm
by monkey boy
At a total loss as to what to do.
Pretty much ready to chuck the towel in with this set up.
Re: Avanti Jetting
Posted: Mon Apr 27, 2015 1:50 pm
by Adam_Winstone
What does your ignition start at and retard to?
Re: Avanti Jetting
Posted: Mon Apr 27, 2015 1:54 pm
by monkey boy
23 to around 16.
Posted: Mon Apr 27, 2015 3:07 pm
by Minority
:oops:
Re: Avanti Jetting
Posted: Mon Apr 27, 2015 3:14 pm
by Minority
monkey boy wrote:At a total loss as to what to do.
Maybe time to ditch the PHBH and go for a flatslide/D slide carb like the Keihin PWK or Mikuni TMX.
I changed my PHBH for a PWK copy (OKO) and it cleaned up the low speed running on my piston ported Rapido setup.
Flatslide/D slide carbs are meant to be better at low throttle openings ( I guess the same would also be true of a flatslide Dellorto).
Re: Avanti Jetting
Posted: Mon Apr 27, 2015 5:41 pm
by Adam_Winstone
monkey boy wrote:23 to around 16.
Providing it isn't retarding too soon, that should be OK, meaning that I'm all out of ideas... for now.
Re: Avanti Jetting
by Adam_Winstone
Check that you haven't got a leak/hole in your float.
