Page 2 of 2
Re: programmable cdi
Posted: Tue Jun 16, 2009 10:53 am
by drunkmunkey6969
What's wrong with one of these? Fully adjustable to your desired adv/retard choice:
http://www.sip-scootershop.com/Products ... Vespa.aspx
Posted: Tue Jun 16, 2009 11:39 am
by fishi
makes same things as the AGUSTO !!!
fishi
Posted: Tue Jun 16, 2009 11:40 am
by drunkmunkey6969
fishi
Yes, but the Agusto isnt adjustable, the AddonV is.
Posted: Tue Jun 16, 2009 11:50 am
by fishi
fishi
yes, you are right, this is what the AddonV can more:
http://www.germanscooterforum.de/index. ... 1066135504
Posted: Tue Jun 16, 2009 5:21 pm
by mark
im talking fully programmable with the choice of a throttle position sensor so you can adjust everything every 5% throughout the whole throttle opening every 500rpm , you will have full control of your ignition,revs,power valve ,throttle position, liguid cooling temp ,speedo and more .
Posted: Tue Jun 16, 2009 9:00 pm
by CANbus
mark wrote:im talking fully programmable with the choice of a throttle position sensor so you can adjust everything every 5% throughout the whole throttle opening every 500rpm , you will have full control of your ignition,revs,power valve ,throttle position, liguid cooling temp ,speedo and more .
yes my intentions are to have fully electric throttle control, clutch and maybe even gear change. By using a hall effect speed sensor on the mag I hope to profile performance based on rpm and also gear selection. The challenge will be to make it an enjoyable ride.
Posted: Thu Jun 25, 2009 9:52 pm
by Adspeed
I know you guys are talking serious tackle here.
Just to let you know the Chiselspeed Advance/Retard unit is in the dealer section.......
i also have a full mappable setup on a smallframe of mine. Dyno testing is coming soon hopefully. But as said before I think it'll be iceing on the cake rather than massiveadvances.
Posted: Fri Nov 20, 2009 2:01 pm
by fishi
to david:
any news refering your RM250 igintion ???
From which model is it? Where do you got it ?
Does this ignition need a battery to work ? it looks like it need one.
Some photos are also of interess!
Have send you PM, but no reply!
fishi
Posted: Fri Nov 20, 2009 3:01 pm
by joee
may i just add...i have not got a danny what the hell you lot are talking about??!!
carry on
