Re: Li3 125 Engine Upgrade questions
Posted: Tue Jul 14, 2015 8:50 pm
chris is right, get the piston bore clearance measured properly unless if you bought it as kit, ask the shop if they checked it. chances are they didn't.
My SR kit was the same in the transfers. its very difficult to remove that, and you may be unlucky, wholly dependent on your set up, that the top edge of the transfers, on the liner, which is where to measure your transfer timing from, may be quite high due to misalignment of the sleeve/liner. As said, this is wholly dependent on the difference between top of barrel and top of piston. The roof of the transfer port is also a critical area for proper running. the casting on these kits is pretty bad, but so is trying to fit a right angled cheap dremel in there for a DIY job. Unless taken to a man with the right tools and the right knowledge, leave them as is. (if you do take it to a tuner, as opposed to getting the right instruments and reading a few books, maybe look over the rest of the 'tidy up/tune' and see what timings you are running, just to get the best picture of what youre working with)
3mm packer? what piston crank combo have you gone for then?
