Page 2 of 2
Re: BGM 225 problems
Posted: Mon Mar 30, 2015 5:07 pm
by bjhart
Thanks for the heads up with Agusto unit. I am talking with both kit supplier and the builder to understand what might be the problem. I will need to check the timing if only to rule it out.
Posted: Mon Mar 30, 2015 6:47 pm
by mick1
Where abouts are you ? Dan (Scooterotica) does a reasonably priced Dyno run that would certainly point you in the right direction, if not identify the problem.
Posted: Mon Mar 30, 2015 7:35 pm
by bjhart
I'm in Suffolk, where is Dan based?
Posted: Mon Mar 30, 2015 7:42 pm
by Spanish Fly
bjhart wrote:I'm in Suffolk, where is Dan based?
Just around the corner! :lol: :lol: :lol:
Posted: Mon Mar 30, 2015 7:45 pm
by mick1
Ripon......North Yorks......maybe a touch too far. I think "Sash" has a dyno in Lowestoft ? bit closer but not too sure by how much.
Posted: Mon Mar 30, 2015 8:55 pm
by bjhart
Thanks yes a bit too far, Lowestoft is only about 60 miles away, ill bear that in mind, what is the business name? I have supplied some set up info to MBD so await their initial feedback first.....I hope it is just the ignition timing that needs sorting out.....fingers crossed
Posted: Mon Mar 30, 2015 9:13 pm
by ArmandTanzarian
Pro Design in Littlehampton or JB Tuning in Southend? They've both got dynos
Posted: Mon Mar 30, 2015 9:40 pm
by Bufficus
John Howe at JAHSpeed (01206 230735) is on the Essex/Suffolk boarder. He maybe nearer depending on where you are.
