Someone must have seen this before and solved the problem
Snails
philz wrote:Try to pick it out with a pin.
Good idea I will try that first. Wish I had a pin! ;)
Snails
diesel wrote:Why do you need to replace that float? If something is wrong with it why not cut it?
As soon as I turn fuel on and start the engine, fuel starts pouring out the over flow hole. Tried a few things but thinking it may be the float
Shipleystevep
Can you get a little self-tapper to grip it?
willow
Main scooter: t5classic
try cutting a match stick to size wet it insert it leave it for 15 mins to swell up and pull it out.
thackers
Hi Ed, if it were mine I'd go along the route of cutting a small groove out between the 2 supports going back to the main body of the float to expose the pin, then with a sharp blade try dragging out the pin along the cut out. That way you could be able to save the float if needed. It only needs to be a small cut out so as to expose the pin enough to grab it with your grips
That'll be the needle sticking. It has happened to me on occasion. What you need to do is tap the carb body with a blunt instrument. Don't go mad. But you may find the valve works correctly then.
Chris in Margate
When you get it out fit a new red tipped needle.
Snails
Chris in Margate wrote:When you get it out fit a new red tipped needle.
Got a red tip in already. :(
Snails
Do you need to do that a lot?
Snails
thackers wrote:Hi Ed, if it were mine I'd go along the route of cutting a small groove out between the 2 supports going back to the main body of the float to expose the pin, then with a sharp blade try dragging out the pin along the cut out. That way you could be able to save the float if needed. It only needs to be a small cut out so as to expose the pin enough to grab it with your grips
That's one of the ideas I had but was not sure whether this would hole the float or damage its buoyancy.
