Page 2 of 7
Re: TSR Evo pipe
Posted: Wed Mar 25, 2015 8:53 am
by Lambretta Sash
Independent test with b4, bolted on and a tweak, its coming back in Saturday for a new reed valve/manifold and probably a tweak further :) https://m.facebook.com/#!/LowestoftLamb ... f=bookmark
Re: TSR Evo pipe
Posted: Wed Mar 25, 2015 9:18 am
by eden
whats the difference between the 3 in terms of what was on before and what was the tweak that gained 4hp?
Re: TSR Evo pipe
Posted: Wed Mar 25, 2015 10:02 am
by onthelam
Numpty question here. There is a version of TSR called DJ? It appears to have the can built into or around the stinger. Any advantage to this or is it just aesthetic?
Just building up my knowledge base.
Re: TSR Evo pipe
Posted: Wed Mar 25, 2015 12:32 pm
by rosscla
That pipe is an copy of an old school style DJ pipe by Dave Webster / MSC from the 1980s
Also very similar to some of the Mikeck designs.
I'd say there are probably better performing pipes out there nowadays and that one is one you'd fit for aesthetic reasons.
Re: TSR Evo pipe
Posted: Wed Mar 25, 2015 1:46 pm
by B-Race Tuning
Onthelam, purely aesthetic, doesn't affect the cones, internal stinger etc. No advantage/ disadvantage (other than standard footboard clearance). I have cut some up that have truncated the rear cone , and that WILL affect the pipes performance but if clever could be built into how the pipe is designed to work, but would be specific to an engine rather as an off-the-shelf pipe as the ones I cut up were.
S
Re: TSR Evo pipe
Posted: Wed Mar 25, 2015 8:49 pm
by phil23fair
Lambretta Sash wrote:Independent test with b4, bolted on and a tweak, its coming back in Saturday for a new reed valve/manifold and probably a tweak further :) https://m.facebook.com/#!/LowestoftLamb ... f=bookmark
Was this a standard TS1 or tuned? If tuned what are the exhaust and transfer timings?
Re: TSR Evo pipe
Posted: Thu Mar 26, 2015 9:24 am
by col68
What carb was used 30mm ,or 35mm ?
Re: TSR Evo pipe
Posted: Thu Mar 26, 2015 10:23 am
by Lambretta Sash
Graph shows as was Ts1 with Taff pipe, next higher reading is with pipe bolted on and highest figure is with ports set up closer to where i like them.
Its coming back Saturday for new inlet and v force 3 and a further tweak ;)
Re: TSR Evo pipe
Posted: Thu Mar 26, 2015 10:46 am
by B-Race Tuning
Hi Sash, do you have a better photo, perhaps clearer and bigger. The one I can see, I can't make out any figures on the scales, or distinguish between the torque curves. What port timings did you go up to on the tune? Nice shaped power curve but can't read rev scales. S
Re: TSR Evo pipe
Posted: Thu Mar 26, 2015 12:20 pm
by Lambretta Sash
If you click on view full size on fb page it will show alot clearer, if i get chance I'll upload it.
This engine is still being developed and really needs a different rod\Stroke combination to get best out of it, at present its 58 x107
