Page 2 of 2
Re: LML engine
Posted: Sun Mar 01, 2015 11:22 pm
by GLscoot
I bought the Worb5 crank, but it was £130ish, if you check out Scooter-Center they should have a decent range and are cheaper than SIP.
Re: LML engine
Posted: Mon Mar 02, 2015 12:29 am
by Juan
Personally I'd go genuine Piaggio, never had any issue using those. Not with lardies at least.
Re: LML engine
by Muttley McLadd
stonerosesmod wrote:What new crank would you suggest that isnt overly expensive?
I've used one of these. It's very smooth.
Re: LML engine
Posted: Mon Mar 02, 2015 7:08 am
by stonerosesmod
I guess another option is take the crank to Harry B for one of his big end bearing and con rod kits for around £80.Cheers lads
Re: LML engine
Posted: Mon Mar 02, 2015 11:02 am
by GLscoot
Juan wrote:Personally I'd go genuine Piaggio, never had any issue using those. Not with lardies at least.
Piaggio crank will not fit on a reed valve engine without modification. The Harry B is a good option. If you contact tass.co.uk he is the official parts supplier for LML in the UK and he will point you in the right direction and only sells genuine LML parts. Yes the crank on the stock engine is not very good but Im sure the replacement from Tasso is of better quality.
This argument goes on and on about LML and Piaggio, but in my opinion the LML is a very good engine and scooter. The fact its Reed Valve gives you loads of options in the future.
Re: LML engine
Posted: Mon Mar 02, 2015 5:01 pm
by stonerosesmod
I wasnt aware of that! cheers.Its only gonna be a budget tune So either a DR177 kit or 5 port 150.Probably worth whipping the crank out nevertheless as i want it to be reliable as i can.
Re: LML engine
Posted: Mon Mar 02, 2015 7:21 pm
by GLscoot
This is the one I used.
http://www.sip-scootershop.com/en/produ ... +_46020000
Same as MM but the standard 57mm model.
