Long Conrods
OzOAP
Main scooter: Vespa PTS1E
Full circle webs from Taffspeed, rod from MB, crank pin made from a Jack Knight Mini idler gear pin, rod shims are from Mini idler gear, I made the web packers.
Just had a look at LTH site. f@@k me that would have saved a lot of work if they had done it 15 years ago!!
grimspeed
Main scooter: gp 283 kx
What do you think is the best reedblock at the moment ?
OzOAP
I've got Tassinari V-Force in everything I have reed valved.
Reeds are just like tyres and two stroke oil though...ask 5 different people and get 6 answers.
grimspeed wrote:What do you think is the best reedblock at the moment ?
Imo I think the new malossi reedblock ,part no 7315550 is the best yet :)
grimspeed
I take it your getting good results on the dyno from these ?
grimspeed
Parts here from LTH ! Now I need to decide what crank 57 or 60 . Can a head be machined for me if the piston is say a mm proud of the top of the cylinder ? Sean ?
If so it looks like a 60mm bell crank ! If not then its some configuration of 57mm !
vesbrettas
i think most 60 cranks use a 20mm pin not 22mm
grimspeed
vesbrettas wrote:i think most 60 cranks use a 20mm pin not 22mm
Soon find out ! The question has been asked !
grimspeed
Looks like your right ! But its ok I can get a pin 20mm x 49mm and theres a conrod 115mm long for a 20mm pin and 18mm small end in Worbs shop !
So all is good ! 8-)Nobody seams to sell the wide spacers for a 20mm pin though but I can make them myself out of bronze !
grimspeed
