Re: lambretta rear hub nut massive mystery.
Posted: Fri Feb 06, 2015 8:29 pm
OK, my apologies, I thought you'd made a typo. Yes that is M18 by the look of it a bit odd to say the least. If you want to use it then I'd suggest cleaning the threads up, check the thread pitch by offering up the M16 to the M18 threads (if they fit together then the M18 thread pitch is 1.5mm), buy a new nut BUT be careful M16 x 1.5 is the original nut and this is a "fine pitch". M18 comes in three different pitches standard is 2.5mm and there are two types of fine pitch 2mm and 1.5mm pitches. Needless to say get the right one to suit your axle. Then fabricate a locking washer.
OR, pull it to pieces and fit the right type and save the M18 version for emergencies (once you have matching nut and washer etc!)
