Page 2 of 2
Re: shortening speedo cable
Posted: Fri Jan 30, 2015 1:39 pm
by ktmh5
goldeneye wrote:the best result ive had is cutting the brass ferrule off the top of the inner cable, as when you tighten the outer onto the speedo, it nips the brass ferrule , and causes it to rub, hence the "gieger counter" action of a lammy speedo. shorten the bottom outer cable 15mm, and cut the brass bit off the top, and I find you have a nice sweep on the speedo.
Top tip that, thanks.
