Page 2 of 2
Re: scootrs disc diagram
Posted: Sun Feb 01, 2015 4:05 pm
by Minority
rbgaz wrote:should the two nuts and bolts on the tie bar on the scootsrs antidive be a little bit lose so it can pivot on brakeing ?
The tie bar must be free to pivot at both ends otherwise you will effectively lock the suspension, the tie bar I got with my anti dive kit had a crude type of rose joint to allow this. I wouldn't leave nuts and bolts loose on suspension though   :o
Posted: Sun Feb 01, 2015 4:08 pm
by Minority
or you can change it for some proper rose joints as I did.
Posted: Sun Feb 01, 2015 4:18 pm
by Minority
dave411 wrote:
TED CRUD wrote:Cheers Lads ,I think i have sussed it . i have searched older posts and noticed the anti-dive bracket needs to be central for a equal performance .too high and stiff too low and it dips under braking
Central to what?
central so you get a 90degree angle like this, or at least that's my theory :lol:
Posted: Thu Feb 05, 2015 9:35 pm
by Adyonekenobi
Nice BGM front dampers, nice powerful disc brake, alloy wheel etc.
So why the crap bracket for the lower damper mounting?
I had them one, both sheard through due to metal fatigue.
I got a great pair of the right trailing links, made by MBD, and they are superb.
Posted: Fri Feb 06, 2015 5:10 pm
by Minority
Adyonekenobi wrote:Nice BGM front dampers, nice powerful disc brake, alloy wheel etc.
One day, but not high on the priority list at the moment.
Posted: Fri Feb 06, 2015 8:56 pm
by Adyonekenobi
Ok
Just keep an eye on those lower brackets for any hairline cracks.
Enjoy your scoot and keep the faith.
Ady
Posted: Sat Feb 07, 2015 1:41 pm
by Minority
Adyonekenobi wrote:Ok
Ady
Sure will Ady, hope they don't have the problem you had ;)
