Page 2 of 2
Re: CDI
Posted: Wed Aug 05, 2015 12:19 am
by kejj
First CDI while riding at low speed and rpm. Second one at idling. They just stop working. No more spark until cdi is changed.
In iron Lambretta cylinders we trust!
Re: CDI
Posted: Wed Aug 05, 2015 5:08 am
by Ilango
My Vijai has a proper Delhi made CDI kit only. So far no issues in the past 700 kms. It was a AC kit on which I introduced an extra wire to make it DC. Still going good. Hope it wouldn't let me down some day in the middle of the street.
Re: CDI
Posted: Wed Aug 05, 2015 11:56 am
by coaster
I've had cheap Indian and Ducatti cdi's fail but I think whatever the make you should give it a fighting. Hands of survival by rubber mounting it. I'm certain that vibration transmitted through the frame is what kills them most of the time
Re: CDI
Posted: Wed Aug 05, 2015 3:56 pm
by kejj
I mount mine on a regular bracket with rubber glued to it and some regular rubber trim between the screws and the CDI so it absorbs some of the vibrations.
Some seem to handle vibration better than others.
Re: CDI
Posted: Wed Aug 05, 2015 6:08 pm
by shocky
I made a battery tray to hold a small battery and above it my wassell unit bolts on next to that is a small block to connect the wires to and under were the battery goes I mounted the cdi unit I welded studs into the tray so that I only need a socket or spanner to remove everything the whole assembly is rubber mounted to the back of the toolbox im going to make another one for this ratter im doing
Re: CDI
Posted: Wed Aug 05, 2015 8:27 pm
by philz
Well decided on the cheapy £10 job and so far no issues.
Re: CDI
Posted: Thu Aug 06, 2015 7:53 am
by Bufficus
BGM stuff looks quality but often it is NOT. I've had 3 stators, 1 CDI and 3 LED rear lights fail. I don't buy their stuff anymore.
Re: CDI
Posted: Fri Aug 07, 2015 8:30 am
by kejj
From now on I will only buy Vespa PX replacement CDI or Mitsubi CDI!
2 BGM CDI fail on me while out on trips seems too much. Lets see if I'll contact Mr BGM on this.
Re: CDI
Posted: Sat Aug 08, 2015 10:55 pm
by philz
Unless BGM contract manufacture their own designs I'm guessing some of the other stuff is just rebadged same as the rest.
