Page 2 of 9
Re: Delving into VSE1M
Posted: Sun Jan 04, 2015 7:59 pm
by gaz_powell
I like this already !!
2.5mm rings are standard P200 and still easily available no problem
Bit of blow past but cylinder bore looks in good nick - I`m sure you will be checking the bore wear before reassembly.
whats the intention with the ignition - change to PX electronic type or retain existing ?
Posted: Sun Jan 04, 2015 8:52 pm
by storkfoot
Gaz, it runs really well as it is. No intention of swapping out the ignition until/ if it packs in. Good shout about piston to bore clearance. I was just planning on slapping in new rings and small end bearing :-0
Posted: Mon Jan 05, 2015 4:20 pm
by weeks
storkfoot wrote:Gaz, it runs really well as it is. No intention of swapping out the ignition until/ if it packs in.
FEMSA rules ;) ................. Good luck with the maintenance mate
Posted: Mon Jan 05, 2015 11:49 pm
by storkfoot
Rings, bearings, seals and a few other bits and bobs on order. The rings had me confused though. I spent 10 minutes searching for 66.0 mm ones :oops:
Posted: Tue Jan 06, 2015 5:13 pm
by gaz_powell
Must admit 66.4 is a strange starting point for a bore !!
You can be forgiven !!
Posted: Sun Feb 01, 2015 6:33 pm
by storkfoot
I managed to find time to split the casings and have a look inside. So far, I don't think I have found anything to worry about.
The gearchange has been very precise and easy. However, the cruciform looks a bit worn. Should I replace?
Also, the Christmas tree, where it engages with the kickstart mechanism, there is a pronounced lip. I'm assuming this is normal and nothing to worry about?
Posted: Sun Feb 01, 2015 6:50 pm
by GLscoot
i always replace cruciform when I split vespa casings & buy genuine piaggio part. I would also change the xmas tree springs, easy enough job.
Posted: Sun Feb 01, 2015 7:13 pm
by storkfoot
OK, thanks. That seems sensible. The cush drive springs is why I split the casings. I suspect they are shot but I'll find out for definite this week
Posted: Sun Feb 01, 2015 7:34 pm
by gaz_powell
Paul
The cruciform on the early gearbox is a weak point (compared to the stronger EFL type) - defo change it and as GL said use only a genuine one (wasp) and a cush drive repair kit. Dont worry about the lip on the xmas tree. More so check the loose kickstart cog/gear - change it if showing signs of rounding and the kickstart buffers.
Gaz
Posted: Sun Feb 01, 2015 7:52 pm
by GLscoot
just out of interest, did these engines not have a clutch oil throw inside.
agree replace kickstart cog as well.
