Re: chain alignment
Posted: Sun Dec 07, 2014 3:33 pm
Yes with an abrasive material dizzy work mindAgent Buchwald wrote:You were running round your rear sprocket?
I get the rear as low as possible so that the clutch doesnt touch the kickstart and then find a drive sleeve somewere near and then figure of 8 it on emery sheet till its spot on prob doesnt mater on my motor but I have time to do it so why notgaz_powell wrote:I use a straight edge (piece of solid steel) across the casing - then measure down with the verniers to the tooth on back sprocket then move to the front - I only adjust on the back if required.
To be honest I never used to bother.
I still don't to get to uptight about - as long as its not massively different.
I think the better the spec/bhp the more need for precision at every point - a humble 125 as opposed to a RB 250 example
Did every engine from factory (Italy and India) have the chain aligned using a bracket and dial gauge ?
