& also take into consideration what
dellorto says
emulsion tubes act as air brakes to slow down the flow of fuel
(got it 10y ago from a friend and promised him not to share the whole document... but an extract is ok )
same in excel
(vollgas=fullthrottle)
area of the tubes holes
a topic follower - ah, mike is also here, hy ginch
asked me if i know how this works. i said:
no i dont, i have some information about it,
but basically i dont care about the details for one easy reason:
for rotary valve si touring tuning up to 25hp on the wheel you need only 2 tubes:
1) be3 is fine with new touring exhaust
2) be2 is needed with rap
dellorto kind of confirms it, i just looked at the table thinking of my ranking
1) be3 is a mixture of 1 and 2.
2) be2 is enrichment in high rpm when the exhaust comes into resonance and needs/sucks a lot
3) all the others are different and - based on know be3 works with EVERY engine 125-225ccm - therefore not needed.
rest is done with idle- & main jet as well as air corrector ( is it the right name? ^^)
it worked, it works and it will work, i tried it on dozens of engines 125-225ccm
never ever used other tubes, or even other slides
no need for it, so why bothering
dont get me wrong: respect folks if you thing about it!
its just my opinion that details are not needed
thereforefmp08 SIsetup wount include such details
but any other usefull information about the awesome si carbs
