Page 2 of 4
Re: A bit boggy - cold weather???
Posted: Sun Nov 16, 2014 12:21 am
by PeteB
Bufficus wrote:Your gadgets and add ons should be taking power from the lighting circuit not the HT.
Tell us more about your engine spec and set up.
And where was it dynoed?
Yep. Surely if there was insufficient energy to create a fat spark the symptom would be a misfire. Likewise for any electrical fault. Choke cable too tight? Muck on choke plunger rubber face?
Posted: Sun Nov 16, 2014 12:28 am
by Yanker
Test 1: Is your S.I.P.(WHATEVERT THAT STANDS FOR), speedometer humid?
Posted: Sun Nov 16, 2014 12:36 am
by alanscottj
Gp150 engine with a Mugello 198 Ultimate kit, Delly 30mm, JL3 pipe, GP200 gearbox 18x47, dyno'd by Jerome @ Readspeed 16bhp and 13 lbs torque in 3rd.
Hits the power around 6,500 - 7,000 rpm, in 1 st, 2nd and 3rd it really hits the power but only if I keep the throttle from totally opening up, then when I get into 4th it is very difficult to get the power up and will lose more power if I open the throttle fully.
Posted: Sun Nov 16, 2014 12:47 am
by Yanker
110% Faulty charger/speedo: check for wetness. If wetress detected then spray with WD40: If Lambretta Concessionaires had ever bothered to up-date their instruction book, then this would be common knowledge
. (theslackcunts)
Posted: Sun Nov 16, 2014 12:49 am
by Bufficus
A mate of mine complained that the SIP speedo I fitted was having an adverse on his lighting. ( The lights got lower the faster he went!) He got on the phone to a renowned dealer in Doncaster who sold him a BGM regulator and a battery he didn't need. When he brought them round for me to fit them the first thing I noticed was spade connector from original regulator to headset was not engaged and was floating about. SIP speedos work fine if wired correctly.
Posted: Sun Nov 16, 2014 12:55 am
by Bufficus
Main jet too big. Gearing too short for pipe.
Posted: Sun Nov 16, 2014 12:58 am
by Yanker
[quote="Bufficus"] the first thing I noticed was spade connector from original regulator to headset was not engaged and was floating about.[quote]
Totally Baffled Big Time! Are we in the 'Lambretta' forum here? Which Lambretta precisely came with a "spade connector from original regulator to headset"?
Posted: Sun Nov 16, 2014 1:02 am
by Bufficus
Yanker wrote:
Bufficus wrote: the first thing I noticed was spade connector from original regulator to headset was not engaged and was floating about.
Spade connector from regulator connected to brown wire? to headset.
Are you as pissed as I am?
Posted: Sun Nov 16, 2014 1:04 am
by Yanker
Bufficus wrote:My Jet Super Lynxss!
Posted: Sun Nov 16, 2014 1:05 am
by Yanker
That explains it
