Re: Varitronic timing setting
Posted: Wed Nov 12, 2014 11:38 pm
There seems to be a little confusion here as to what the requirements are for which engine and with which version of the Varitronic. I've had a quick look at the link to recent fitting instructions but they cover a huge range of motors, with very different compression ratios, operating RPM ranges, pipe characteristics, porting specs and therefore need some very different timing settings (starting, mid range and full RPM). Much of the setting information is great for a kitted high BHP/high revving motor, which is confusing the requirement for a standard Cento motor.
I for one wouldn't want to guess what setting I should be running at (well, I would... but I'd also take responsibility for potentially getting it wrong and blowing it up!), rather, I'd go back to the supplier and ask them for their recommendation. Centos are quite different to the SI - SIII motors that many of us have experience of setting up variable ignitions, especially kitted motors that have massively different timing requirements, so I'd not want to start guessing at your expense. I can't even remember what timing I ended up with on the Cento, J125, and my own Starstream 125 converted Vega but I do recall that they don't need to be retarded as far as even a standard SIII running on today's fuel, which will be related to the low port specs and fairly low compression and low revving pipe.
My advice would be to email Cambridge Lambretta, Tino or a.n.other supplier and see what first-hand experience they have and/or for their recommendation.
Nelson is quite right that I've made previous comments about people getting advance/retard settings wrong (even getting the starting point or end point right but having the wrong ignition curve profile for your a specific motor), which can leave you running too advanced and overheating (seizure or piston holing) or too retarded and the motor losing most of the power that it would otherwise be making. Too many people get their setting wrong and then blame it on the ignition kit, whereas they should be concentrating on getting the settings right.
Best of luck.
Adam
PS - I know that I said I'd not be guessing your timing requirements but I will give you something to consider...
The standard ignition requirement for a J100 was (pre-unleaded, pre-ethanol, when pump petrol burned cooler) 24 degrees btdc, in the same way that most SIIIs were 23 degrees btdc and higher revving GPs were running 21 as standard. Most people are now running lower spec SIIIs on 19 degrees btdc, higher revving standard'ish motors at 17 degrees btdc and kits often at 16 or less! Following this logic and basic reduction in advance, to keep cool, you may also want to be looking for your 24 (original 60s timing) to 19 degrees at maximum revs. To improve low rev power and gain a performance improvement from your investment in this ignition kit, the starting point (fast tickover) may well be back at the original 60's firing point of 24... or more advanced, which will give more power when pulling away from a standing start and assist massively when carrying a passenger. Remember that you must get the timing too advanced and it will overheat and cause issue.... but too retarded (closer to TDC) and the motor will make little/no power
In order to get this right YOU MUST be able to strobe your ignition timing to see what the range of firing point is, from tickover to maximum revs (you'll do this on the stand and see the firing point swing over the range, retarding as revs rise). There should be no 'guessing' when it comes to setting ANY electronic ignition, especially not an auto advance/retard ignition.
Best of luck.
Adam
