no spark
lambro
shocky wrote:see if your actually getting a spark from the green stator wire it will be weak then add the cdi leaving off the ign switch green as previously stated
Can you actually get a spark direct from just the green on an electronic stator plate without going through the stator.
I didn't think you could :?
lambro
woody wrote:Only seem to be getting a spark from the yellow wire when trying direct onto metal and thats with both stators and flywheels
Check what colour wire is soldered to your pick up on the stator, there are Indian ones wired with wrong colours,
The wire from the black pick up box (usually red, but can be yellow) goes to the CDI, with the White and Green.
woody
Don't have an augusto fitted and the right green wire is deffo out
