Page 2 of 2
Re: clutch top plate and kickstart shaft problems
Posted: Wed Oct 01, 2014 5:02 pm
by byron
and it's useful to coat the kickstart shaft and clutch top plate with engineers blue before reassembly.
then if there is any rubbing you can see exactly where to remove some metal
but don't be tempted to take too much from the kickstart shaft, as they can break there, and it's always the ones that have been ground down too much that shear...
Posted: Wed Oct 01, 2014 8:32 pm
by Bombay Mix Pilot
I had a similar problem, kickstart shaft inner bush in the side casing was protruding too far. Bush tapped in reshim on kickstart shaft, job done. Had this on a couple of side casings. Hope this is of some help.
Andy
Posted: Thu Oct 02, 2014 7:41 am
by brianc
Thanks for all the advice lads,
Brian
Posted: Fri Oct 03, 2014 5:56 pm
by brianc
andy you were right,the kickstart bush was protruding slightly,tapped it in as you said,also measured the clutch shim,came in at 1.4mm,ordered up a 0.8mm,will see how that lines up.
brian.
