Page 2 of 3
Re: Snapped crank
Posted: Sat Sep 06, 2014 6:36 am
by psychedelicropcircle
MB does a good job of these.
Re: Snapped crank
Posted: Sat Sep 06, 2014 7:53 am
by joespeed
can you show us more photos of the cylinder skirt,it looks like it has knocked off the thinner machined spigot,this may not impede the running of the kit!
Re: Snapped crank
Posted: Sat Sep 06, 2014 8:48 am
by Ian Hepworth
It's not the worst damaged casing I've seen but it's a fiddly repair. It needs building up with weld then the crankcase mouth and gasket face need sorting.
The cylinder could be repaired with a steel liner.
Re: Snapped crank
Posted: Sat Sep 06, 2014 10:45 am
by dapper
Would have thought Oiltek could repair this.
Re: Snapped crank
Posted: Sat Sep 06, 2014 2:56 pm
by Muppet
get it welded it'll be rite :P
Re: Snapped crank
Posted: Sat Sep 06, 2014 3:33 pm
by vicvega
https://www.flickr.com/photos/127594304 ... 153656401/
https://www.flickr.com/photos/127594304 ... 156232382/
https://www.flickr.com/photos/127594304 ... 133596316/
Closer pics of the barrel, you can still see a piece of the rod embedded in the side wall. Is it possible to salvage this, the head is perfect no damage at all. :?:
Re: Snapped crank
Posted: Sat Sep 06, 2014 6:07 pm
by joespeed
steel liner should fix the cylinder,
Re: Snapped crank
Posted: Sat Sep 06, 2014 6:25 pm
by lambro
langcourts in Weston Super Mare can repair the barrel, and re-nicasil it.
If you don't want a steel liner that is.
Shaun.
