Page 2 of 5
Re: Wassel Failure
Posted: Fri Sep 05, 2014 8:38 pm
by Bilko
All clear
Re: Wassel Failure
Posted: Fri Sep 05, 2014 9:12 pm
by eden
obviously you have changed HT lead and plug cap?
also checking the pickup and ht coil with a multi meter isn't always 100% true,,, I have a stator that test good which ive carried round for nearly 2 years as a spare, earlier this year a mate of mine needed to change his stator on the way to Whitby so he tried my spare, it didn't fire at all, in fact it didn't spark at all. when I got home I tested it again on the multimeter and it still showed good readings.
Re: Wassel Failure
Posted: Fri Sep 05, 2014 11:02 pm
by Bilko
Yes mate. Lead and cap and 3 stators
Re: Wassel Failure
Posted: Sat Sep 06, 2014 8:43 am
by goldeneye
petrol tap.
Re: Wassel Failure
Posted: Sat Sep 06, 2014 10:57 am
by Bilko
Changed the tap
Re: Wassel Failure
Posted: Sat Sep 06, 2014 4:11 pm
by eden
Come on then Bilko, we give in, what is wrong with it then?
Re: Wassel Failure
Posted: Sat Sep 06, 2014 4:26 pm
by Bilko
LOL! I haven't a clue. It's kept me off the road all bloody summer! It looks like I'm going to miss the 4 Nations next month. The only rally I was getting to this year.
Re: Wassel Failure
Posted: Sat Sep 06, 2014 5:24 pm
by eden
have you tried an air test on it yet? pretty easy to do even with out a kit just by using innertubes
Re: Wassel Failure
Posted: Sat Sep 06, 2014 6:14 pm
by Monty
Out of all thats been done and checked I can not see any mention of CDI. I went through the mill with timeing and different stators earler this year. I tried 3 stators and found the timing moving all over the place simply changing the cdi. I used expensive and cheaper ones but in my case timing could easily change by 10 degrees simply changing the cdi. This in conjuction with an M tech got me thinking they were a waist of time. All stators metered out OK. I settled for a BGM one in the end the next step was to mount it on rubber buffers after comments about vibrations. Like you I seem to have spent the summer in the shed. Good luck.
Re: Wassel Failure
Posted: Sat Sep 06, 2014 6:47 pm
by Bilko
Haven't done an air test.
Tried different CDI's Monty.
