Page 2 of 3
Re: Avanti kit seizure
Posted: Mon Aug 25, 2014 6:41 am
by Livi- Graeme
Yes opened mouth. What you thinking something pulled in via the carb?
Posted: Mon Aug 25, 2014 6:45 am
by Livi- Graeme
[img][/i
[IMG]http://i1379.photobucket.com/albums/ah1 ... wo0uuc.jpg[/img]mg]heres a photo of the piston. If you zoom in to the plug it looks a nice colour
Posted: Mon Aug 25, 2014 7:45 am
by coaster
wich had
There's a lot of blow by the rigs, was it possible to get them out intact? would be interesting to know what the ring gap was. 2000 miles on a set of rings isn't much really even open mouthed byt there was definitely a fair bit of leakage going on which might be why it heat sized
Posted: Mon Aug 25, 2014 8:43 am
by Chris in Margate
Looks suspiciously like it took in grit ftom the road.
Posted: Mon Aug 25, 2014 9:05 am
by mick1
When a mates TS1 siezed it took the plating off in one chunk about the size of 2p piece. The "pitting" effect seems strange it'll be interesting to see what the experts say.
The six miles from fill up is concerning.....are you 100% you put oil in ?
I'm sure Ron is the first port of call as he'll be as interested as anyone.
Posted: Mon Aug 25, 2014 9:53 am
by CANbus
Hi what kit number is it?
Posted: Mon Aug 25, 2014 12:24 pm
by Spanish Fly
Livi- Graeme wrote:Yes opened mouth. What you thinking something pulled in via the carb?
Doesn't look like anything has been bouncing around in the combustion chamber.
SF
Posted: Mon Aug 25, 2014 8:48 pm
by OAP
Hi all, thought I would try and give my verdict on what has happened to Graeme's cylinder.
We have had a total of 8 Holed or partially holed pistons which have not actually seized solid even after depositing alloy down the cylinder, obviously through running weak mixture.
Plus one which was using too much oil resulting in carbon build up on the inside of the piston which then blocked the two oil holes in the piston, then went on to wash carbon deposits up and down the cylinder wearing the plating.
This instance however is completely different, there are hundreds & hundreds of scooters running without filters up & down the country without any mishaps, on this occasion Graeme was running without side panels which do actually defect some debris, I can only conclude that something entered the carb and was trapped at the exhaust port gouging the piston. What is interesting is that there are only a few marks on the crown of the piston yet the side of the piston is heavily scored! This is NOT an conventional heat seize.RM
Posted: Mon Aug 25, 2014 9:05 pm
by Avantone
Whatever the cause, it'll be worth flushing that recently bought fuel out completely just in case.
Posted: Mon Aug 25, 2014 9:20 pm
by Chris in Margate
On our way to Amiens this year one of our group took a large piece of grit in that jammed in a reed petal. He was running open mouthed with panels on and we had just ridden over about 5 miles of regritted road. Fortunately it didn't enter his TS1 cylinder but it held us up for 3 hours in the rain
