Re: Drive side seal retainer
Posted: Wed Sep 03, 2014 11:18 pm
In case its ever of use to someone else......
Two problems:
Firstly, the halite washer I had was 2.5mm uncompressed as oppposed to 1.5mm uncompressed on the new one.
Secondly, I used an mb retainer plate which is 0.7mm thinner.
After I had finished I only had 0.6mm clearance betweeen the crank and case. Minimum is 0.5mm. It doesn't take a genius to work out that neither solution would have worked in isolation.
Two problems:
