Page 2 of 3
Re: Px disc bleeding problem
Posted: Tue Aug 19, 2014 6:52 pm
by ducksta
pump the lever as normal then pull in and tie wrap it leave over night all the bubbles will have come to the top, then fill up jobs a good un.
Posted: Tue Aug 19, 2014 9:47 pm
by weedodger
is there a bearing in the bleed valve? im not a vespa man sorry
Posted: Tue Aug 19, 2014 10:03 pm
by Shaunbond
[quot e="dennis"]Is that a non return valve?,can't see how that works if it is.[/quote]
It allows the air and fluid to pass through the valve but when you release the lever it doesn't allow air back into the system.
I've just done the linked brakes on an X9 this way, a pain as there are 3 calipers and a bypass valve but it works.
Posted: Tue Aug 19, 2014 10:43 pm
by Knowledge
I have to bleed a brake on my Nexus last week and I tried everything from operating the lever to sucking (Mitivac) and a syringe. No progress.
Finally, I tried opening the bottom nipple (with a hose attached) and really pumping the lever fast. This really moved the bubbles (at last) and all was good with the world.
Posted: Tue Aug 19, 2014 11:53 pm
by weedodger
god knows, tried one way valve, no joy
tried syring from bottom through pipe onto valve, filled the reservoir, still nothing,
bed time,,,, one morning to fix, or its here for a week, brighton calling, help
Posted: Wed Aug 20, 2014 1:43 pm
by ducksta
do it my way m8 leave it over night and it will be ok
Posted: Wed Aug 20, 2014 2:11 pm
by dennis
This non return valve does it go inline or after the bleed nipple,
Posted: Wed Aug 20, 2014 4:56 pm
by Shaunbond
after the bleed nipple, in the middle of the piece of pipe you attach to the nipple.
Posted: Wed Aug 20, 2014 6:08 pm
by dennis
Right i'm with you now, how we used to bleed brakes in the old days, they used to make bleed nipples with spring non return valves, put some on my 1600e cortina,if only.
Posted: Wed Aug 20, 2014 6:49 pm
by weedodger
https://imagizer.imageshack.us/v2/679x3 ... B0WpxH.jpg
oops, pic, fluid leaking from hose. found the problem, next prob, changing hose, px125 08 plate, best option?
day andd half wasted on that job, bloody vethpas
