Re: temp gauges
Posted: Thu Aug 21, 2014 8:08 pm
How easy would it be to add a fuel gauge? One that is accurate, would be nice to know how much you have left, especially if you have a long range tank
that's a good idea, although I'd forget to re set the bareden wrote:the rts1000 speedo im currently testing has a feature where you can set a distance in miles that then shows a bar that reduces until the mileage you set has been reached, the bar then turns red and if you click on the bar with your finger it shows how many miles past the set mileage you had set.
I use this as a fuel gauge, I know how many miles my scooter will do on a full tank, so every time I fill up I reset the bar and know when I need to fill up, I have it set currently that it turns red when I have around 30 miles left in the tank.
very useful indeed
