Casa Conundrum
Ah, I see what you mean. Yes, drained fuel tanks and seemed to flow okay. No sign of debris in there either. I'm coming around to Eden's point of view. It just doesn't like me. ;)
paulmgreen
Have you measured the fuel flow through the tap ?
www.JPPLambretta.co.uk
Mr G in NYC
Main scooter: SX200
That carbs too small ....you need a 25mm Dellorto .......
Mine runs like a top ....I use it every day . G.
Chris in Margate
Float sticking on pivot and staying shut. Remove and run a small drill bit through by hand and ensure it is free to rise and fall without any friction.
johnd
Main scooter: 1970 Dl125
Check the flow of petrol through the carb with the float bowl removed. Sounds like the problem. Check the float is free to move full up and down on its pin, check the float needle.
dapper
Nev, does it rev OK when on the stand or does this problem only occur when you are sitting on the scoot, riding it ? Check that the fuel pipe doesn't get pinched when you sit on the bike. Have you checked the flow rate into a container? Should be a pint a minute from memory. Good Luck ;)
Trojan
Main scooter: LAMBRETTA INNOCENTI
speedy wrote:I think by letting, he means just letting the fuel flow into a container or bowl to make sure it keeps flowing.
Sorry ,should have explained clearer, There was also an issue with one fuel tap, whichever of the three positions it was in,somehow seemed to be letting in air???? finally had enough and took it apart to find the gasket with the holes to allow fuel in was FECKED, MMMM binned it and replaced with a new one happy days.....hope this helps also...... 8-)
I've had the chance to have a look at a couple of things tonight. Most important of which is the flow rate I suppose. I got 900mls in the space of a minute, which I seem to think isn't bad. That was with a Cam Lam reverse exit fuel tap. I've checked the brass ferrules in the mouth of the carb and there doesn't appear to be any obstruction. The float moves quite freely too. Previous to that I had checked the seat of the needle valve and ran a tiny drill piece through it. As that can be obstructed. And just for good measure I have put another petrol cap on. I'll have to give it a bit of a run and report back.
nuttyboy
Main scooter: lambretta
You need a 30mm Dellorto,,bin the jetex
Sent from my KFTT using Tapatalk 2
I'm wavering, but I don't think I'll go quite that far.
