Page 2 of 2
Re: GP stripped headlight thread
Posted: Fri Aug 08, 2014 8:47 pm
by jason frost
Or tap it to 3.5 mm
Posted: Fri Aug 08, 2014 10:14 pm
by rosscla
jason frost wrote:Or tap it to 3.5 mm
And you have a ready source of screws in your light switches :D
Posted: Fri Aug 08, 2014 10:16 pm
by ricalnic
Yup, worked for me, and yes light switch screws are the ones for the job
Posted: Mon Aug 11, 2014 1:57 am
by rbgaz
Yes Sef is correct I've used black tape to hold my gp headlamp in for bout 5 years works a treat it's never fell out it also givs the scoot a sporty look as well. Happy days
Posted: Mon Aug 11, 2014 12:09 pm
by Snails
sydduckett wrote:RB gaz on here will go halves with you, he's got his taped up with masking tape and it's looks sh$t..... :D
He will be along shortly to admonish me for the above comment.... :lol:
ha that's my current solution too...the other side is fine but the rattle/wine from it does my head in!
Thanks for all the suggestions. I'm a cheap skate so I will probably go with one of the suggestions which are a (no offense) bodge :)
Posted: Mon Aug 11, 2014 12:10 pm
by Snails
too short I think? :)
Posted: Thu Nov 20, 2014 5:08 pm
by Snails
I'm operating at my normal snail like pace but I have purchased some JB weld and the appropriate drill bit to tap it out to its original size.
Before I apply the weld I'm wondering if there is anything I can do to make it easier for me to ensure the tap goes down the path of the original thread? I don't fancy placing my headstock in a vice and then trying to dot punch a mark into the weld for me to drill down
Posted: Thu Nov 20, 2014 7:05 pm
by rosscla
Put a small amount of grease on the tap and build up the stuff round it, let it go off and wind the tap out?
Posted: Sun Nov 23, 2014 10:38 pm
by TS1-200
I've repaired a few of these in my time, with a method that I read about on this forum, difficult to explain, easy to do, get a 4mm pop rivet (I think) can't rememeber the exact size as I haven't done one for a while, pull out the steel rod and drill through the knackered thread and insert the ally part of the pop rivet through the back of the stub that you have drilled out, you can put a small amount of superglue on to be sure it's firm, if it sticks through the front just dremel off the bit that sticks out, then just tap the correct thread in it, when putting the ally bit in the hole you can file or dremel the wide part so that it fits nice and flush, this method works well.
Posted: Sat Nov 29, 2014 7:58 pm
by Dell Oughta
http://www.memfast.co.uk/shop/Vprod2.asp?cat=3
get yourself some of these (Stainless Steel, Flat Head, Splined Body Rivet Nuts threaded M4) , only £2.20 a pack, open up the old threaded hole in the headset to fit em nice n snug, araldite them in place to secure.....job done.
Mike
