Gearbox problems
joespeed
here is the correct way to assemble the gearbox.
1. top gear (smallest) with its boss toward you
2.third boss down towards hub
3.second boss down again
4.ratchet upwards
simple as 'hoop la'
regards
joe
Ian Hepworth wrote:It does matter which way each gear goes round. If you have one the wrong way round you won't be able to select that gear as it will jump straight out of gear.
Fair comment, I was going from what I'd read in Stiky's book where he says make sure the slotted sides do not face each other, but you do need to start with the 4th gear with the flat side towads the bearing.
Either way, it seems a likely reasin for the problem ;)
rog60
Main scooter: Indian GP200
Just for info:- Assembled a gearbox with 4th gear wrong way round and kept jumping out of 3rd gear. So as Joespeed says, there IS a right and wrong way to assemble a gearbox. I can never remember so I use the Home Workshop Manual description which, for me, is a little clearer.
come on chaps...........get a grip
of course there is a right way...............
:D
simon
Thanks for your help guys, I will open it up and have a look
Arfur
Playstation gamer tag: hulkascooby
Simon any joy if this is wullies SX engine then run it up to Rikkis and we'll sort it out fro you no worries 8-)
simon
Arfur yes its Wullies, he sold me it 3 weeks ago, the second gear is hard to select, I don’t want to damage the gearbox so it’s of the road but I will take it up to Ricky’s
Cheers Simon :D
Arfur
No worries buddy let me know when you takin it over and I'll make sure I'm there mate :mrgreen:
