Page 2 of 2
Re: socket size range
Posted: Wed Jul 16, 2014 12:54 am
by corrado
The only sizes you're likely to use are 8, 10, 11, 13, 14, 19, 24 and 27 mm. Just carry a 3/8 tommy bar about 150 mm [for the 19 and 24 .... the 19 fits the front axle nuts on mine but some use 21 mm dome nuts] and a 3/8 to 1/2 adaptor for the 27 mm socket for the rear hub. If you have SIP tubeless rims you'll need a 12 mm socket and you'll need a deep 13mm socket if your spare is a split rim.
Posted: Wed Jul 16, 2014 9:17 am
by Chris in Margate
Add a 7mm to that on a small 1/4 in ratchet for some carb clips and those 2 little blighters on top of the mag housing.
