Page 2 of 2
Re: 172 holed piston nearly
Posted: Wed Jul 09, 2014 2:29 pm
by speedy
I wouldn't put Shell fuel in any scoot just out of precaution. I took me P2 to the I O W the year before last and ran out of fuel a mile before a garage because I fefused to stop at the shell I was nearest to. Last year Andy Gatecrashers took his T5 172 Pinasco to I O W and fuelled up on Shell. Five mile down the road seized it up. We stripped it, cleaned the bore and fuelled at the esso just up the road and it was fine again after that. Shell is not good stuff.cheers,Speedy.
Posted: Wed Jul 09, 2014 3:06 pm
by soulboy
is this the one and only speedy from swad as was
Posted: Wed Jul 09, 2014 3:29 pm
by joeythescooterboy
Never had an issue with Shell, in fact I seek it out, mind I only use the super not the fuelsave cak.
Posted: Wed Jul 09, 2014 3:47 pm
by soulboy
just been looking for A new piston and there graded A to D WHATS THAT ALL ABOUT
Posted: Wed Jul 09, 2014 4:33 pm
I think the barrel should be stamped with the corresponding letter mate, all down to tolerances I think.
Posted: Wed Jul 09, 2014 5:06 pm
by soulboy
cheers joe I cant find nothing on my barrel but its less than 12 months old do I need the correct letter
is it worth changing the attomiser its a 104 or some thing like that im asking all this cause at nearly a ton a pop I don't wanna shag a piston again cheers
Posted: Wed Jul 09, 2014 6:53 pm
Ideally you need the correct piston for the barrel, if you've melted the piston crown I don't think you'll be able to see which letter it was???
Perhaps you could have it measured by a grown up and work it out from there?
As for carb settings......... last 172 reed I played with had 40 slide, 50 idle, X2 needle (can't remember which notch,) AV264 atomiser and 135 main, it also had a Sean Brady reworked crank.
It was quite rapid but the lad I did it for didn't have it long so can't say how long it lasted.
Posted: Sat Jul 12, 2014 7:30 pm
by soulboy
its a standard carb joe but as been matched to the inlet
Posted: Sat Jul 12, 2014 8:17 pm
by speedy
soulboy wrote:is this the one and only speedy from swad as was
As they said in Highlander, ''There can be only one!''.
Posted: Sat Jul 12, 2014 11:03 pm
So where did I get "reed" from?
Another senior moment methinks.
