Page 2 of 3
Re: my S2 bitsa
Posted: Tue Sep 16, 2014 5:09 pm
by gaz_powell
Full Engine spec is pretty straight forward - nothing special
Casing is a SIL 150 converted at Oiltek - blended to match barrel
Steel lined TS1 to 66mm using IT175 piston with 1.5mm off bottom of barrel
Standard reed set up with MB manifold
RD 400 rod in SIL webs
19/46 with SIL 200 g/b
IWIS chain with nylon guides
Genuine SIL ignition rewired and slighly lightened SIL flywheel
Gonna use a 30mm carb - probably a 30mm phbh
Taffspeed copy pipe
Re: my S2 bitsa
Posted: Sat Sep 20, 2014 8:49 am
by gaz_powell
a bit arse first but few shots of work in progress before paint - dry build
headset top work
forks - Italian set converted to take dampers and the turning mudguard - had to turn a ring to put round the bearing race and the side brackets (like vespa) for the side fixings
dry build finished
Gaz
Re: my S2 bitsa
Posted: Wed Sep 24, 2014 11:29 pm
by gaz_powell
Norrie
"you add the Ian Curtis shadowplay dance off to a treat yrs ago?? Haha"
I still have !!!!
Gaz ;)
Re: my S2 bitsa
Posted: Wed Sep 24, 2014 11:35 pm
by speedy
Stunning Gaz,really stunning, I just love the paint. Looking forward to seeing her in the flesh.Speedy.
Re: my S2 bitsa
Posted: Thu Sep 25, 2014 11:10 pm
by TED CRUD
Nice one Gaz !!!
Re: my S2 bitsa
Posted: Wed Oct 01, 2014 8:45 pm
by gaz_powell
cheers for the comments ......... even with the dubious theme !!!
Re: my S2 bitsa
Posted: Thu Oct 02, 2014 5:28 pm
by jazzyb
Cracking job love the colour 8-)
my S2 bitsa - finished 9except one bit !
Posted: Thu Feb 12, 2015 7:42 pm
by gaz_powell
Finally got my S2 finished - going for test on Saturday and hopefully ran in for S`bro
Horncasting badge is at the signwriters
Looking forward to running the steel liner in .................not !
Re: my S2 bitsa - finished except one bit !
Posted: Thu Feb 12, 2015 9:24 pm
by goldeneye
BELTER Gaz!
Posted: Thu Feb 12, 2015 10:04 pm
by cartmel808
Very very nice... the colour, the style & the finish all look spot-on... Well done 8-) ....and good luck with running it in :D
