my S2 bitsa - finished except one bit !
gaz_powell
Full Engine spec is pretty straight forward - nothing special
Casing is a SIL 150 converted at Oiltek - blended to match barrel
Steel lined TS1 to 66mm using IT175 piston with 1.5mm off bottom of barrel
Standard reed set up with MB manifold
RD 400 rod in SIL webs
19/46 with SIL 200 g/b
IWIS chain with nylon guides
Genuine SIL ignition rewired and slighly lightened SIL flywheel
Gonna use a 30mm carb - probably a 30mm phbh
Taffspeed copy pipe
gaz_powell
a bit arse first but few shots of work in progress before paint - dry build
headset top work
forks - Italian set converted to take dampers and the turning mudguard - had to turn a ring to put round the bearing race and the side brackets (like vespa) for the side fixings
dry build finished
Gaz
gaz_powell
Norrie
"you add the Ian Curtis shadowplay dance off to a treat yrs ago?? Haha"
I still have !!!!
Gaz ;)
speedy
Stunning Gaz,really stunning, I just love the paint. Looking forward to seeing her in the flesh.Speedy.
TED CRUD
Nice one Gaz !!!
Smash Ya Pastie
Washington Posse s.c
gaz_powell
cheers for the comments ......... even with the dubious theme !!!
jazzyb
Cracking job love the colour 8-)
gaz_powell
Finally got my S2 finished - going for test on Saturday and hopefully ran in for S`bro
Horncasting badge is at the signwriters
Looking forward to running the steel liner in .................not !
goldeneye
BELTER Gaz!
cartmel808
Very very nice... the colour, the style & the finish all look spot-on... Well done 8-) ....and good luck with running it in :D
    Users browsing this forum: No registered users and 52 guests
