Page 2 of 2
Re: scooter vibrating
Posted: Thu May 29, 2014 8:58 pm
by Arborman
I have the same problem.... mines an S2 and just had my silent blocks changed but still does it... Usually occurs around 40 - 45 mph.
Just purchased some uprated BGM ones (as the ones I had replaced were the small original type) they look the business so lets hope it reduces the vibration somewhat.
I am assuming( rightly or wrongly) its because of these small block engines being uprated with bigger barrel and pistons etc etc , this must have something to do with it...please fingers crossed
Posted: Thu May 29, 2014 9:07 pm
by crooky
let me know how you get on thanks hope it sorts it out was looking at the mb ones myself.
Posted: Thu May 29, 2014 10:57 pm
by kejj
I had started noticing greater vibrations, again at certain speeds/revs. Firstly though of the engine mounts.
It eventually turned out to be the crank was out of balance. the two webs were misaligned.
Posted: Fri May 30, 2014 3:09 pm
by corrado
My headset vibrates like crazy at tick over so I'm going to replace the top fork bearing with loose balls to see what effect, if any, that has.
Posted: Fri May 30, 2014 8:23 pm
by GP Kevo
Could also be the endplate roller bearing. Mine went and made the engine vibrate at low rpms unless the clutch was pulled in.
Posted: Sat May 31, 2014 6:57 pm
by Arborman
Well Crooky,
Just had my silent blocks replaced today with the uprated BGM 3 hole.....the vibrating has gone. Sorted
Posted: Tue Jun 03, 2014 9:03 pm
by crooky
thanks pal looks like that's what I'll be getting thanks again
Posted: Thu Jun 05, 2014 2:51 am
by corrado
I think I'll go that route too as the driveside one looks off centre so must be wearing.
